Applying Holds Manually
Automatic hold processing handles the majority of order holds, but there may be circumstances that require clerks to place order or quote headers, lines, or schedules on hold manually. Determine the effect of manual holds on order processing and planning consideration on the Hold Processing page.
Orders that are placed on hold manually must have the holds removed manually.
Pages Used to Apply Holds Manually
Header Holds/Change Reasons Page
ORDENT_HDR_RSN
Place or remove manual order holds at the header level.
Line Holds/Change Reasons Page
ORDENT_LINE_RSN
Place or remove manual order holds at the line level.
Hold Information Appearing on Sales Orders
Schedule Holds/Change Reasons Page
ORDENT_SCH_RSN
Place or remove manual order holds at the schedule level.
Order Hold Workbench - Overview Page
HWB_OVERVIEW
Use this page to view analytic data across sales orders on hold. Hold data can be searched/summarized using business unit, hold code or customer.
