Checking Price and Availability for Product Kits
Use the Product Kit Availability inquiry component to determine availability for product kits.
This topic discusses how to view and determine product kit availability.
Pages Used to Check Price and Availability for Product Kits
| Page Name | Definition Name | Usage |
PRODKIT_AVAIL |
View information on available, complete kits and navigate to see the supply and demand placed against each component part. The availability of product kits depends on the supply of each component. |
Kit Availability Detail Page |
PRODKIT_AVL_DET |
View details about individual components of the product kit that you selected on the Product Kit Availability page. |
Related Topics
Product Kit Availability Page
Use the Product Kit Availability page (PRODKIT_AVAIL) to view information on available, complete kits and navigate to see the supply and demand placed against each component part.
Navigation:
| Field or Control | Description |
Include |
Includes all supply sources by default, but you can exclude a source by deselecting the appropriate check box. If you have PeopleSoft Purchasing installed, approved purchase orders and PeopleSoft Inventory MSRs always appear. Note: The Scheduled Production option is unavailable for entry unless you have PeopleSoft Manufacturing installed. The Approved PO Request option is unavailable for entry unless you have PeopleSoft Purchasing installed. |
Lookup |
Click the button after selecting a product to populate the Kit Component Information section of the page |
Per |
Identifies whether the number of units displayed in the Quantity field is by ASY (assembly) or by ORD (order). |
Inventory Item |
Populated by the Product Definition Overview page in PeopleSoft Inventory. |
OK to Ship Without |
Displays the selection that you made on the Kit Component Text page when you defined the product kit. |
