Order Change Maintenance Page
Use the Order Change Maintenance page (OMEC_ORDCHG_FLD) to modify the list of records that can be changed in Sales Order Change.
Navigation:
Order Management, and then Electronic Commerce, and then Identify Order Changes
Field or Control Description
Inventory Edit
If this check box is selected, the filed change must be validated against PeopleSoft Inventory.
Work Field
Used by PeopleCode to determine whether the change can still be made in PeopleSoft Inventory. The Electronic Commerce process (OM_EC) returns a value of Yes if the field can be changed, and a value of No if the field cannot be changed. For example, if the change request is to change the carrier, the program checks PeopleSoft Inventory to verify that the change can still be made. If the order line is already shipped, Electronic Commerce returns a value of No.
Propagation Rule
Shows whether the change requests are made to the line, schedule, or both. For example, if the line has only one schedule, a change request to change the carrier on the order line is propagated down to the schedule. If more than one schedule exists, then the change is not propagated.
Alternate Field
Enter if the field name is different at the corresponding level.
Invoice Edit
If this check box is selected, the field change is validated at the schedule level if the schedule is invoiced.
Configured Kit Edit
If PRODKIT_EDIT is selected in the database, then the field can be changed.
The system already defined the fields that can be changed in the sales order change. If you want to modify the list of records, use the Order Change Maintenance page. You also need to add the new fields on the SALES_ORDER_CHANGE_LOAD message to permit the change.
