Setting Up VAT Defaults
Two main components control VAT defaults: the VAT Defaults Setup component and the Services VAT Treatment Defaults Setup component. You can access these components from the common VAT menu (Set Up Financials/Supply Chain, and then Common Definition, and then VAT and Intrastat, and then Value Added Taxes) or from the Order Management Business Unit definition, product definition, or customer pages. If you access these components from the VAT menu, the driver that you select determines the fields that appear. If you access either of these components from the application pages, the component from which you are accessing it determines the fields that appear.
VAT Driver VAT Driver Keys Country State Applicable to Regular VAT Defaults Applicable to Services VAT Treatment Defaults
Sales Line Identifier
Note: PeopleSoft Order Management uses the product ID value for the identifier.
SetID
Identifier Table
Identifier
Optional
Optional
Yes
Yes
Sales Line Identifier Group
Note: PeopleSoft Order Management uses the product group value for the identifier.
Sales Line Identifier Group SetID
Identifier Table
Optional
Optional
Yes
Yes
Customer Location
Customer SetID
Customer ID
Address Sequence Number
Optional
Optional
Yes
Yes
Customer
Customer SetID
Customer ID
Optional
Optional
Yes
Yes
Business Unit
Optional
Optional
Yes
Yes
VAT Entity Registration
VAT Entity
Country
Required
Optional
Yes
No
VAT Country
Country
Not applicable
Optional
Yes
No
