Viewing Alternate Sources of Supply
Use the Claimback/Supply Source tab in the line grid area of the Order Entry Form page (ORDENT_FORM_LINE) or Shipment Schedules page
Navigation:
The Find Alternate Supply Sources button appears if advanced sourcing is used for the PeopleSoft Order Management Business Unit. The Manual or Automatic Availability Option must be selected on the Order Entry Features page for the business unit.
| Field or Control | Description |
Source Type |
The value is provided by default from the highest priority sourcing option returned from the supply source engine if the availability option on the Order Management Business Unit is Automatic. Otherwise, it is set based on the alternate source of supply you choose. |
Disposition |
The value is provided by default from the highest priority sourcing option returned from the supply source engine if the availability option on the Order Management Business Unit is Automatic. Otherwise, it is set based on the alternate source of supply you choose. If you change the sourcing option on the Alternate Sources of Supply page, it will update the value. Note: If multiple schedules are available for the line, the source type becomes the original default (Distribution Network or Inventory Business Unit) and the Disposition is Direct Ship. If the product is marked as Direct Ship from Supplier, then the Source Type is New Requisition and the Disposition is Direct Ship. |
Click the Find Alternate Sources button to perform additional sourcing on the Alternate Sources of Supply page. |
Supply Source Data |
Click the link to access the Supply Source Detail page. |
Claimback ID |
The claimback defaults and can be changed. |
