Pay/Bill Management Web Libraries
This table lists the web libraries that are used and delivered with Pay/Bill Management:
Web Library Name Description
WEBLIB_FO_PB
PeopleSoft Pay/Bill Management web library.
WEBLIB_IB
Generates PeopleSoft Integration Broker functions.
WEBLIB_MSGWSDL
This is the record behind the page for the enterprise integration point (EIP) Web Services Description Language (WSDL) generation.
WEBLIB_PORTAL
Contains the following five fields with FieldFormula iScript PeopleCode, each of which relate to a functional area of the portal:
PORTAL_HOMEPAGE: Support for homepage runtime interaction, including the homepage version of the menu navigation.
PORTAL_NAV: Main support routines for navigation.
PORTAL_HEADER: Support for the header portion of the page and some generic routines.
PORTAL_DYN_TEMP: Support for the dynamic template.
PORTAL_PGLT_PREV: Support for the pagelet preview functionality.
WEBLIB_PT_NAV
Contains iScripts for the menu pagelet and left-hand navigation for transaction pages.
WEBLIB_RPT
Contains iScript for the Run report to window output option. Supports access to the new browser window.
WEBLIB_XMLLINK
Generates PeopleSoft Business Interlinks XML functions.
