PeopleSoft Project Costing
When setting up PeopleSoft Project Costing, make sure that you:
Enable the application messages for estimates and actuals on the Projects Options page.
Select the Time and Labor Actuals, Time and Labor Estimates, Time and Labor Contractor, and Time and Labor for Billing check boxes in the Time and Labor Interface group box on the Projects Options page.
Ensure that you select the Project and Activity Team check box for each PeopleSoft Project Costing business unit.
Enable PeopleSoft Project Costing integration with PeopleSoft Time and Labor on the Installation Options - Projects Integration page.
Select the Load Time Automatically check box in the Time and Labor Integration region of this page.
When configuring project types, make sure that the project types referred to in the PeopleSoft Pay/Bill Management project profiles do not have default rate sets associated with them, otherwise, the system will not be able to automatically create contract custom rate sets for the temporary assignments.
