Payables WorkCenter Page - Incomplete Vouchers (Work Management Enabled)
Use the Payables WorkCenter page when Work Management is enabled to access and manage outstanding transactions in various views.
Navigation
Select the Payables WorkCenter tile.
This example illustrates the fields and controls on the Payables WorkCenter with Work Management enabled.
Payables WorkCenter with Work Management PI54
When Work Management is enabled, there are two changes on the WorkCenter page:
  • The View drop-down box appears above the grid.
  • Additional action options are added to the Actions button.
  • The original action options remain. The additional (Work Management) action options depend on the View option selected.
    See Enterprise Components: Understanding the Work Management Framework, Actions by View section for more information.
