Setting Up Work Management for the Payables WorkCenter
This list provides the steps to setup the optional Work Management feature for the Payables WorkCenter.
  1. Use the EOXC_USER role to access the Work Management setup pages.
  2. Access the Enterprise Components: Work Management Link ID's Page.
  3. Search for the corresponding Link ID (component ID) for each type of transaction where you want to use the Work Management feature.
    Payables pages and their corresponding Link ID are:
    Link ID Description
    AP_INCOMPLETE_VOUCHER
    Incomplete Vouchers
    AP_INC_CONTROL_GROUP
    Unverified Control Groups
    AP_IMG_INVC_FOR_REVIEW
    Image Invoices for Review
    AP_SUPPLIER_MESSAGE
    Messages from Suppliers
    AP_RECYCLED_VOUCHER
    Recycled Vouchers
    AP_BUDGET_CHECK_ERROR
    Budget Check Errors
    AP_DOC_TOL_EXCEPTION
    Document Tolerance Exceptions
    AP_EXCEPTIONS
    Match Exceptions
    AP_PMNTRQST_FOR_REVIEW
    Payment Requests for Review
    AP_PMNTRQST_PND_APPRV
    Payment Requests Pending Approval
    AP_APPROVE_VENDOR
    Suppliers Pending Approval
    AP_SCHED_PMNT_HOLD
    Scheduled Payment on Hold
  4. Select the View button to access the Enterprise Components: Enable Work Mgmt Exception Page.
  5. Select the Enable option to activate the Work Management feature for that transaction.
  6. Follow instructions in the Enterprise Components documentation for the Enterprise Components: Enable Work Mgmt Exception Page to complete your setup.
  7. Use the EOXC_USER role to access the Payables WorkCenter.
