Voucher Correction and Mass Maintenance
PeopleSoft Payables provides two methods for correcting unpaid vouchers:
The Voucher Maintenance Search component (VCHR_CORRECT_SRCH) and Voucher Maintenance component (VCHR_CORRECTION).
These components enable you to search for vouchers by a number of voucher fields and error criteria, and then search for the exact voucher lines, distribution lines, or scheduled payments that you want to correct.
The Voucher Maintenance component enables you to handle modifications and add voucher and distribution lines to unposted vouchers of any size, without the burden of calling up the entire voucher. It is particularly useful for modifying large vouchers with many voucher or distribution lines.
The Voucher Mass Maintenance component.
This component enables you to search for vouchers by a number of voucher fields and then update specific fields across all of the vouchers that meet your criteria.
You can also use the Voucher Mass Maintenance component to close, delete, and unpost multiple vouchers that share particular field values.
The Voucher Mass Maintenance component is ideal for situations such as a reorganization that results in a department ID change: you search for all unpaid vouchers with distribution lines that include the old department ID and update them all at once with the new department ID.
