Delivered Workflows for Issue Management
This topic discusses the delivered Issue Management workflows, which includes these events:
Create Issue Notification
Assign Issue Notification
Update Issue Notification
These workflows are active only if Issue Management workflow has been enabled on the Installation Options - Program Management page (INSTALLATION_PGM).
Create Issue Notification Description
| Information Type | Description |
Event Description |
Click the Submit button on the Issue page (PC_IM_ISSUE) after you save the issue. |
Action Description |
The system sends a worklist item and email to the issue owner. |
Notification Method |
Worklist and email Note: Email notification is defined in the PGM_ISSUE_OWNER PeopleTools generic notification template. |
Create Issue Notification Workflow Objects
Event |
SUBMIT |
Approval Rule Set |
None |
Business Process |
PGM_ISS_MGMT |
Activity |
NOTIFY_OWNER |
Role |
None |
Assign Issue Notification Description
Event Description |
The following events trigger this event: Assign a resource to an issue. Change a resource assignment for an issue. |
The system sends a worklist item and email to the assigned resource. If you change the resource that is assigned to an issue, a worklist item and email are sent to both the previously and newly assigned resources. |
Worklist and email Note: The email notifications are defined in the PGM_ASSIGN_TO and PGM_REASSIGN PeopleTools generic notification templates. |
Assign Issue Notification Workflow Objects
Event |
SAVE |
Approval Rule Set |
None |
Business Process |
PGM_ISS_MGMT |
Activity |
NOTIFY_ASSIGN_TO |
Role |
None |
Update Issue Notification Description
Event Description |
Modify the Issue Summary, Issue Description, Issue Priority, Issue Status, Resolution Description, Actual Resolution Date, Issue Notes, or Issue Attachments field in the Issue Management component (PC_IM_ISSUE) to trigger this event. |
The system sends an email to the employees who are listed on the Issue - Interested Parties page (PC_IM_INT_PRTY). |
Note: Email notification is defined in the PGM_NOTIFY_INT_PARTIES PeopleTools generic notification template. |
Related Topics
