Request for Detail Project Plan
This topic discusses the Request for Detail Project Plan workflow.
Description
| Information Type | Description |
Event Description |
This event is triggered when an approver clicks the Costing button on Project Request Approval page (BC_PRJ_APPROVAL). |
Action Description |
The system sends a worklist item to the individual who is identified in the Project Manager field on the Project Request page (BC_PROJ_REQUEST1), and changes the project request status to Costing. |
Notification Method |
Worklist |
Workflow Objects
Event |
COSTING_PLAN |
Approval Rule Set |
None |
Business Process |
PPK_PROJ_APPR_BP |
Activity |
PPK_PJ_COST |
Role |
None |
