Setting Up General Control Data
To set up general control data, use these components:
  • Change Control Management (PC_CHC).
  • Issue Priorities (PC_IM_PRIORITY).
  • Issue Status (PC_IM_STATUS).
  • Issue Types (PC_IM_TYPE).
  • Project Category Setup (PGM_CATEGORY_SETUP).
  • Application Area Setup (PGM_APPLAREA_SETUP).
  • Application Setup (PGM_APPLICAT_SETUP).
  • Project Risk Type (PGM_RISK_TYPE).
  • Release Type (PGM_RELEASE_TYPE).
  • Release Management (PGM_RELEASE).
  • Root Cause Area Setup (PGM_RCA_SETUP).
Pages Used to Set Up General Control Data
Change Control Template Page
PC_CHC_CFG
Create or modify a change control template.
Issue Priorities Page
PC_IM_PRIORITY
Define priorities that are used to classify activity, project, or program issues.
Issue Status Page
PC_IM_STATUS
Define statuses that are used to classify activity, project, or program issues.
Issue Types Page
PC_IM_TYPE
Define issue types that are used to classify activity, project, or program issues.
Category Page
PGM_CATEGORY_SETUP
Define categories that are used to classify programs, projects, and project requests.
Application Area Page
PGM_APPLAREA_SETUP
Define application areas used to group similar applications together. Applications identify a module or specialty within a software product.
Application Page
PGM_APPLICAT_SETUP
Define applications used to identify a module or specialty within a software product.
Project Risk Types Page
PGM_RISK_TYPE
Define risk types and select the risk type status.
Release Type Page
PGM_RELEASE_TYPE
Define and maintain release types by SetID.
Release Page
PGM_RELEASE
Create and edit release information.
Root Cause Area Setup Page
PGM_RCA_SETUP
Define root cause areas that you can specify when you enter a project or budget change request.
Use the Change Control Template page (PC_CHC_CFG) to create or modify a change control template.
Navigation:
Setup Financials/Supply Chain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Change Control Tmplt
This example illustrates the fields and controls on the Change Control Template page. You can find definitions for the fields and controls later on this page.
Use this page to specify which change control attributes are to be monitored and to what extent. Options for the fields on this page are:
Field or Control Description
Off
Select to disable change control for this attribute. This is the default setting.
On
Select to enable change control for this attribute. They system automatically generates the user name, change made, and date for the changes.
User Input
Select to enable change control for this attribute and to require users to enter a reason for the change. When you select this option, the Change Control User Input page automatically appears after users save the changes. This option is not available for project transactions or estimate to complete changes.
Use the Issue Priorities page (PC_IM_PRIORITY) to define priorities that are used to classify activity, project, or program issues.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Issue Priorities
This example illustrates the fields and controls on the Issue Priorities page. You can find definitions for the fields and controls later on this page.
PeopleSoft Program Management delivers issue priority values of HIGH, MEDIUM, and LOW. Add a new row on this page to inactivate a priority or enter a different priority description.
Select a Description value of High, Medium, or Low for the priority that you are defining. You can select these priorities when you enter or edit an issue using the Issue page.
Issue priorities are represented by these colored visual indicators when issues appear on pagelets:
High Priority Level
The system displays this symbol when the selected priority for an issue is mapped to the high priority level.
Low Priority Level
The system displays this symbol when the selected priority for an issue is mapped to the medium priority level.
Medium Priority Level
The system displays this symbol when the selected priority for an issue is mapped to the low priority level.
Issue Status Page
Use the Issue Status page (PC_IM_STATUS) to define statuses that are used to classify activity, project, or program issues.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Issue Status
This example illustrates the fields and controls on the Issue Status page. You can find definitions for the fields and controls later on this page.
Issue Status page
The statuses that you define on this page are available for selection when you enter or edit an issue using the Issue page. You must define issue statuses before you can enter an issue. Enter the effective date, status, and description for the issue status. You can select from only active issue statuses when you create an issue.
Issue Types Page
Use the Issue Types page (PC_IM_TYPE) to define issue types that are used to classify activity, project, or program issues.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Issue Types
This example illustrates the fields and controls on the Issue Type page. You can find definitions for the fields and controls later on this page.
Issue Type page
The issue types that you define on this page are available for selection when you enter or edit an issue using the Issue page. You must define issue types before you can enter an issue. Enter the effective date, status, and description for the issue type. You can select from only active issue types when you create an issue.
Category Page
Use the Category page (PGM_CATEGORY_SETUP) to define categories that are used to classify programs, projects, and project requests.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Categories
This example illustrates the fields and controls on the Category page. You can find definitions for the fields and controls later on this page.
Category page
The categories that you define on this page are available for selection when you create or edit a project using the Project Definitions - General Information page. Enter the status and description for the category.
Use the Application Area page (PGM_APPLAREA_SETUP) to define application areas used to group similar applications together.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Application Area
This example illustrates the fields and controls on the Application Area page. You can find definitions for the fields and controls later on this page.
The application areas that you define on this page are available for selection when you create or edit a project using the Project Definitions - General Information page. Specify the status and description for the application area. You can select from only active application areas when you create applications.
Application Page
Use the Application page (PGM_APPLICAT_SETUP) to define applications used to identify a module or specialty within a software product.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Applications
This example illustrates the fields and controls on the Application page. You can find definitions for the fields and controls later on this page.
Application page
The application that you define on this page are available for selection when you create or edit a project using the Project Definitions - General Information page.
Application Area
Enter the area to which the application belongs. An application can only belong to one application area. You must set up application areas before you can set up applications.
Software Title
Select the software package to associate with this application. The field appears only if you have PeopleSoft Information Technology Asset Management installed.
Use the Project Risk Types page (PGM_RISK_TYPE) to define risk types and select the risk type status.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Risk Types
This example illustrates the fields and controls on the Project Risk Types page. You can find definitions for the fields and controls later on this page.
Risk Type page
Specify the description and status for the project risk type. You can select from only active project risk types when you create risks.
Release Type Page
Use the Release Type page (PGM_RELEASE_TYPE) to define and maintain release types by SetID.
Navigation:
Setup Financials/SupplyChain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Release Types
This example illustrates the fields and controls on the Release Type page. You can find definitions for the fields and controls later on this page.
Release Type page
Specify the status and description for the release type. You can select from only active release types when you define a release.
Release Page
Use the Release page (PGM_RELEASE) to create and edit release information.
Navigation:
Program Management, and then Release Management, and then Define Release Definitions
This example illustrates the fields and controls on the Release page. You can find definitions for the fields and controls later on this page.
Release page
Release Manager
Enter the employee ID of the person responsible for managing this release.
Release Status
Select the status of this release from these options:
  • Active: Indicates that this is a current release.
    This is the default status for new releases.
  • Inactive: Indicates that this is an old or cancelled release that remains in the system for historical purposes.
  • Pending: Indicates that this is an upcoming release.
Note: For all of the online pages containing release information, the system displays only active or pending releases.
Original Release Date
Enter the date on which this release is due. If the release date changes, enter the revised release date into the Current Target Release Date field.
Enter the revised target release date. For a new release, the default value for this field is the current date. For all of the online pages containing release information, the system displays the current target release date.
Release Type
Enter the type of release. You must define release types on the Release Type page before you can select a release type for a release.
Additional Fields
Click to access the Release Additional Fields page and enter additional information. The fields on the Release Additional Fields page are user-defined fields for informational purposes only.
Add Attachment
Click to add an attachment.
Note: You must have the File Attachment option set on the Installation Options - Project Costing page for attachments to work.
See PeopleSoft Asset Lifecycle Management, Enterprise Service Automation, Financial Management, Staffing Front Office, and Supply Chain Management Product-Specific Installation Instructions located on Oracle's PeopleSoft My Oracle Support website.
File Name
Displays the name of the file that you upload.
Added By, Name, and Date/Time Stamp
Displays information about the user who adds the attachment, and the date and time that the upload occurred.
Use the Root Cause Area Setup page (PGM_RCA_SETUP) to define root cause areas that you can specify when you enter a project or budget change request.
Navigation:
Setup Financials/SupplyChain, and then Product Related, and then Program Management, and then General Options, and then Setup PGM Root Cause Areas
This example illustrates the fields and controls on the Root Cause Area Setup. You can find definitions for the fields and controls later on this page.
You can specify a root cause area for informational purposes when you enter a project change request or a budget change request. Enter the root cause area description and status.
