Common Elements Used with PeopleSoft Fluid User Interface for Financials and Supply Chain Management
A banner appears at the top of every PeopleSoft Fluid page, includes the page label, and these standard buttons
Field or Control Description
Actions List button (Actions List button)
Select the Actions List button to see a list of available actions for the current window. Access pages to personalize window content or sign out.
Home button (Home button)
Select the Home button to return to the main PeopleSoft Home page.
NavBar button (NavBar button)
Select the NavBar button to expand the NavBar window, where you can select window content from options, such as Recent Places, My Favorites, Navigator, My Preferences, and Fluid Home. Select again to collapse the NavBar window.
Notifications button (Notifications button)
Select the Notifications button to view actions and alerts in a notifications window.
Personalize NavBar icon (Personalize NavBar icon)
Select Personalize NavBar to access the personalization window, where you can add and remove selected tiles from the NavBar.
Related Actions icon (Related Actions icon)
Select Related Actions to view available related actions.
Right Arrow (Expand Pane)
Select to expand a pane. The pane may contain tabs that you can select to view detailed information.
Show Filters icon (Show Filters icon)
Select Show Filters to open a pane that displays filters. Filters can be used to reduce the number of records in the results section.
