Common Elements Used with PeopleSoft Fluid for Project Management
Field or Control Description
Options Menu icon (options menu icon)
Click the Options Menu icon to open additional options for the page. Specific options are described for each page below.
Chart Options icon (chart options icons)
Select an option to view the data as a vertical bar chart, line chart, pie chart, or horizontal bar chart.
View Result options icon (view result options icons)
Select an option to view the results as a grid or a list.
Related Actions icon (related actions icon)
Select the Related Actions icon to view and perform additional transactions. Specific actions are described for each page below.
Show Filters icon (show filters icon)
Click the Show Filters icon to open a right side panel that allows you to select specific facets on which to search. Facet values depend on the type of search.
