Prerequisite
Before exporting time, expense, and progress log information to Project Costing, ensure that the following fields are set as you want them in the System Analysis Types group box on the Project Costing Integration page (Set Up Financials/Supply Chain, Install, Installation Options and select Project Costing Integration). The system is delivered with default settings, but you can change them:
Expenses
Mobile Time / Expense
sPro Assignment Incident
sPro Progress Log
See Application Fundamentals: Installation Options - Project Costing Integration Page.
