Project Compression Log
The system logs each compression run in the PC_COMPRESS_LOG table. The log retains compression details such as run date, parameters used, and status. Additional details, such as date option, analysis group, contract, and SQL, are logged if used.
The compression log enables the user to perform actions such as viewing history or archiving, purging, restoring, and rolling back data.
