Summary Transactions
The Project Data Compression process summarizes transaction data based on run control parameters, such as date, analysis group, contract, or customized SQL. The Project Data Compression process should be performed only on completed projects and activities. The system does not check the status of a project or activity before running the Project Data Compression process.
A compression template is used to define how project transactions are to be summarized during the process. The template enables users to choose the dates they want to roll up and the rollup calendar. Microsoft and Sybase database platforms have a limit of 32 fields of detail.
For example, a compression template is created using these parameters:
  • Date Roll up Level is Monthly.
  • Roll up Date to Use is Start of Period.
  • Calendar ID is 01 Monthly.
  • Dates Selected are Accounting Date and Transaction Date.
The 01 Monthly Calendar for year 2007 is set up:
  • Period 01: January 01, 2007 to January 31, 2007
  • Period 02: February 01, 2007 to February 28, 2007
  • And so on
Before the compression process runs, the detail rows in the PROJ_RESOURCE table are:
Business Unit Project Activity Amount Acct Date Transaction Date
US004
ABC
001
100.00
01/01/2007
01/05/2007
US004
ABC
001
200.00
01/15/2007
01/15/2007
US004
ABC
001
500.00
02/02/2007
01/31/2007
US004
ABC
001
600.00
02/28/2007
02/28/2007
US004
ABC
001
100.00
02/28/2007
02/01/2007
After the compression process runs, the detail rows in PROJ_RESOURCE table are:
US004
ABC
001
300.00
01/01/2007
01/01/2007
US004
ABC
001
500.00
02/01/2007
01/01/2007
US004
ABC
001
700.00
02/01/2007
02/01/2007
