Tables Populated by the Project Data Compression Process
The Project Data Compression process stores data in transaction history and summary tables. The process updates these tables when you summarize data from the Project Transaction table:
  • Project Transaction History (PROJ_RES_ARCH)
  • Project Summary History (PROJ_SUM_ARCH)
  • Project Resource (PROJ_RESOURCE)
  • Project Compression Log (PC_COMPRESS_LOG)
