Project Copies
Any project and activity to which you have access is available to be copied to new or existing projects and activities. You can copy project and activity-level information, project and activity team, and transactions to a new project.
You must open a project to copy information from that project. The Copy Template Option 1 and Copy Template Option 2 pages in the Project Costing Options component for the business unit identify the tables that the system uses to copy data into projects and activities that you create or modify by using a copy of an existing project.
You can access the Project Copy feature by using any of these methods:
  • Create a new project by selecting the Project from Copy option on the Project Definitions - General Information - Add a New Value page.
  • Modify an existing project or create a new project by clicking Copy Project on any Project General component page of the project that you want to copy.
  • Create a new project by navigating to the Copy Project page from the Project Costing, and then Utilities menu navigation folder.
