Setting Up Feeder and Pricing Summarization
Pages Used to Set up and Use Feeder and Pricing Summarization
| Page Name | Definition Name | Usage |
Application Fundamentals: Installation Options - Project Costing Integration Page. |
INSTALLATION_PCINT |
Select the product and pricing options. Determine summarization options in the Summarization Options group box. |
PC_SUM_TEMPLATE |
Define summarization templates, which are rules for feeder integration applications and the Project Costing Pricing process. |
PROJECT_EXPRESS |
View transaction information and drill to the transaction detail. |
Steps to Setting Up and Using Feeder and Pricing Summarization
To set up and use feeder and pricing summarization:
Select the desired product and pricing options in the Summarization Options group box on the Project Costing Integration page.
Define summarization templates using the Summarization Template page.
Run the integration processes from feeder applications.
Run the Pricing process to price transactions in the PROJ_RESOURCE table if the Pricing process is not automatically called from the feeder interface process.
Drill to the transaction detail from the Transaction List page.
