Setting Up Project ChartFields
To set up project ChartFields, use these components:
  • Source Types (PROJ_RES_TYPE)
  • Categories (PROJ_CATG_DEFN)
  • Subcategories (PROJ_SUBCAT_DEFN)
  • Relate Source Type/Category (PROJ_TYPE_CAT)
  • Relate Category/Subcategory (PROJ_CAT_SUB)
Use these component interfaces to load data into the tables for this component:
  • PC_RES_TYPE_INTFC
  • PC_CATG_DEFN_INTFC
  • PC_SUBCAT_DEFN_INTFC
Pages Used to Set Up Project ChartFields
Source Types Page
PROJ_RES_DEFN
Create and modify source types.
Categories Page
PROJ_CATG_DEFN
Create and modify categories.
Subcategories Page
PROJ_SUBCAT_DEFN
Create and modify subcategories.
Relate Source Type/Category Page
PROJ_TYPE_CAT
Relate source types to categories.
Relate Category/Subcategory Page
PROJ_CAT_SUB
Relate categories to subcategories.
Source Types Page
Use the Source Types page (PROJ_RES_DEFN) to associate source types to categories.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Project Costing, and then Transaction Options, and then Setup PC Source Types
This example illustrates the fields and controls on the Source Types page.
Source Types page
Field or Control Description
Category
Enter a category to associate with the displayed source type. Available values are based on the Project Type Category Prompt table (PROJ_TYPE_CAT). Add more rows to add additional categories.
Relationship
Enter a description of the relationship for each type and category combination.
Use the Relate Category/Subcategory page (PROJ_CAT_SUB) to relate categories to subcategories.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then Project Costing, and then Transaction Options, and then Relate Category/Subcategory, and then Relate Category/Subcategory
This example illustrates the fields and controls on the Relate Category/Subcategory page. You can find definitions for the fields and controls later on this page.
Subcategory
Enter a subcategory to associate with the displayed category. Available values are based on the Project Subcategory Prompt table (PROJ_CAT_SUB). Add more rows to add additional subcategories.
Relationship
Enter a description for the new category and subcategory relationship.
