Understanding Integration of PeopleSoft Project Costing with Microsoft Project
This topic lists prerequisites and discusses:
  • PeopleSoft Project Costing and Microsoft Project integration.
  • Copying data from PeopleSoft Project Costing to Microsoft Project.
  • Copying data from Microsoft Project to PeopleSoft Project Costing.
As of FSCM Update Image 48, the integration with Microsoft Projects and PeopleSoft Project Costing is no longer supported. The Microsoft Integrator, in its current state, is still available, and customer can continue to use the functionality at their own discretion.
Please note that all menu options (CREFs), objects, and source code remain on your system. As of FSCM Update Image 48 PeopleSoft does not support the integration with Microsoft Projects with all past, current, or future PeopleSoft Update Image.
