Prerequisites
The PeopleSoft Project Costing integration is intended for use with Microsoft Project, desktop edition only. Projects residing in Microsoft Project Server must be saved locally by means of Microsoft Project Standard prior to integration. Before running the Microsoft Project Integration for the first time, you must:
Install the PeopleSoft - Microsoft Project Integrator on the network.
See PeopleSoft Financials, ESA and Supply Chain Management Product-Specific Installation Instructions located on Oracle's My Oracle Support website.
Specify the Third-Party Data Exchange default options on the Installation Options - Project Costing Integration page.
See Application Fundamentals: Installation Options - Project Costing Integration Page.
The PeopleSoft - Microsoft Project Integrator is an application that must reside on at least one computer that is available on the network in order for integration to take place. The computer on which it resides requires these two components:
FTP service or access to an FTP share directory.
Microsoft Project application.
