Understanding Project Creation Options
Project Costing provides project creation tools that eliminate the need to re-create key information for each new project. To create a new project, you can perform any of these actions:
Add a new, blank project and enter the required information.
Use a predefined project template or copy any existing project as a starting point for a new project.
Receive projects from feeder systems such as PeopleSoft Program Management or PeopleSoft Proposal Management.
Create a project from a Microsoft Project file.
