Understanding the Projects WorkCenter - My Work
This page shot provides an example of how the Project Costing WorkCenter - My Work section can be set up
This example illustrates the fields and controls on the My Work. You can find definitions for the fields and controls later on this page.
Project WorkCenter My Work pagelet
In this example, the My Work section is divided into these groupings:
  • Pre-Billing Exceptions Group
    • Billing Over the Limit Transactions
    • Deferred Billing Transactions
    • PC (Project Costing) Unpaid Vouchers
    • Missing Journal Analysis Type
    • Journals with Default Analysis Type
    • Bill Rows Not Created
  • Setup and Maintenance Exceptions
    • Missing Project Managers
    • Blank Project Type
    • Inactive Project Exceptions
    • Activities Not Linked to Contract Lines
    • Update Project Template Status
  • Project Data Compression
