Common Elements Used on the Projects WorkCenter - My Work Pagelet
This topic provides common elements used for:
  • Action options.
  • Page options.
Action Options
Users can select a project and perform these actions:
Field or Control Description
Manager Transaction Review
Select to access the Manager Transaction Review page for the project. This option is available in Bill Rows Not Created.
Mark Journal Unpost
Select to unpost the journal. This option is available in Missing Journal Analysis Type.
Review Bill Plan Information
Select to access the Billing Plan General page for the contract.
Review Contract Header
Select to Contract - General page.
Review Contract Terms
Select to access the Review Contract Terms page for a selected contract, project, and activity. This page enables a user to attach a project or activity to a contract line.
Review Contract Workbench
Select to access the Contracts Workbench page for the contract to which the project is assigned.
Review Journal Lines
Select to access journal related information. This option is available in Missing Journal Analysis Type.
Review Project Information
Select to access the Project Definitions - General Information page.
Review Project Transactions Pivot
Select to access the Project Transactions Pivot page. The page enables a user to review project transaction data from the project summary tables.
Review Rate set / Rate Plan
Select to access the rate set or the rate plan that is associated to the project. This option is available in Bill Rows Not Created.
Review Resource Details
Select to access the Project Resource Plan page (if PeopleSoft Program Management is installed), or the Project Team page (if PeopleSoft Program Management is not installed).
Review Transaction List
Select to access the Transaction List page for the project and activity.
Review Voucher Information
Select to access voucher related information. This option is available in PC Unpaid Voucher.
Page Options
These fields and definitions are common in the Projects WorkCenter - My Work Pagelet
Run Pricing
Click to open the Pricing run control page.
Process Monitor
Click to access the Process Monitor. Users can view the status of a job that was submitted.
Refine Filter Criteria
Application Fundamentals: Understanding Delivered WorkCenters and Dashboards
