Defining Sampling Codes
To define sampling codes, use the Sampling Codes component (QS_MFDS_TYPES). This topic discusses how to define sampling codes.
Characteristic class and sampling frequency types are for reference and documentation only. System and processing behavior are not affected by their settings.
Pages Used to Define Sampling Codes
| Page Name | Definition Name | Usage |
QS_CLASS_TYPE |
Maintain characteristic class types that note differences in inspection criticality or function. You use characteristic class types when defining measurement plans. |
QS_FRQ_TYPE |
Maintain sampling frequency types that note the frequency for taking inspection samplings. You use sampling frequency types when creating control plans. |
Characteristic Class Types Page
Use the Characteristic Class Types page (QS_CLASS_TYPE) to maintain characteristic class types that note differences in inspection criticality or function.
Navigation:
Enter a class type code to qualify the quality control characteristics, either by criticality or function. Class types are associated with characteristics when you create measurement plans.
Related Topics
Sampling Frequency Types Page
Use the Sampling Frequency Types page (QS_FRQ_TYPE) to maintain sampling frequency types that note the frequency for taking inspection samplings.
Navigation:
Enter a frequency code to specify the recommended frequency of inspection for a control plan.
Related Topics
