Integration With Other PeopleSoft Applications
A quality function parents control plans with associated sample data and is the first point of integration between Quality and other PeopleSoft applications. The function provides awareness of the different fields that are common to an integrating application. Quality functions are created to synchronize fields with other PeopleSoft applications and eliminate the need to enter placeholders in unused fields.
To configure Quality to operate in a given data collection environment:
  1. Define a quality function.
  2. Identify the characteristics that you want to monitor on a measurement plan.
  3. Create control plans that bring together a measurement plan and specific process identifiers.
Currently, Quality integrates with Purchasing, Inventory, and Production Management and delivers the following predefined quality functions to accommodate the integration between products:
PeopleSoft Application Quality Function Function Description Hierarchy Fields Trace Fields
Purchasing
RECV_INSPECT
Receiving inspection.
INV_ITEM_ID
VENDOR_ID
DISTRIB_LINE_NUM
DISTRIB_SEQ_NUM
LOT_ID
OPRID
RECEIVER_ID
RECV_LN_NBR
SERIAL_ID
TAG_NUMBER
VENDOR_LOT_ID
Inventory
RMA
Inspect items on a returned material authorization.
INV_ITEM_ID
CONFIG_CODE
CONTAINER_ID
INV_LOT_ID
QTY_INV_RECV
RECEIPT_DTTM
RECEIVER_ID
RETURN_FROM_BU
RETURN_FR_CUST_ID
RMA_ID
RMA_LN_NBR
SERIAL_ID
STORAGE_AREA
COMPLETIONS
Record completions against a production ID or schedule.
COMPL_OP_SEQ
INV_ITEM_ID
MACHINE_CODE
PRDN_AREA_CODE
PRODUCTION_TYPE
WORK_CENTER_CODE
BOM_CODE
DT_TIMESTAMP
INV_LOT_ID
OPRID
PRODUCTION_ID
RTG_CODE
COMPL_NO_MC
Same as COMPLETIONS, except no machine code field.
COMPL_OP_SEQ
INV_ITEM_ID
PRDN_AREA_CODE
PRODUCTION_TYPE
WORK_CENTER_CODE
BOM_CODE
DT_TIMESTAMP
INV_LOT_ID
OPRID
PRODUCTION_ID
RTG_CODE
COMPL_NO_OP
Same as COMPLETIONS, except no machine code, work center code, or compl op seq (completion operation sequence) fields.
INV_ITEM_ID
PRDN_AREA_CODE
PRODUCTION_TYPE
BOM_CODE
DT_TIMESTAMP
INV_LOT_ID
OPRID
PRODUCTION_ID
RTG_CODE
Quality
QUALITY
Emulates the field structure that PeopleSoft 7.5 Quality uses. Use this if you upgrade from PeopleSoft 7.5 to PeopleSoft 8.
INV_ITEM_ID
MACHINE_CODE
QC_STEP_ID
STATION_CODE
WORK_CENTER_CODE
CREW_CODE
DT_TIMESTAMP
LOT_ID
OPRID
OP_SEQUENCE
PRDN_AREA_CODE
PRDN_DUE_SHIFT
PRODUCTION_ID
SERIAL_ID
TASK_CODE
TOOL_CODE
