PeopleSoft Quality Integrations
PeopleSoft Quality integrates with the following PeopleSoft applications and with third-party applications:
PeopleSoft Purchasing.
PeopleSoft Inventory.
PeopleSoft Manufacturing.
Third-Party applications.
When you inspect material received against a purchase order, you can use PeopleSoft Purchasing to initiate a quality data-entry session automatically in PeopleSoft Quality.
When material is returned on an return material authorization (RMA) in PeopleSoft Inventory, you can use PeopleSoft Quality to enter detailed quality information against the material received. After the material is received on an RMA, the system creates a quality data-entry session.
When recording operation completions and scrap information against a production ID or schedule for any production type (production, rework, or teardown) using PeopleSoft Manufacturing, you can immediately initiate a data-entry session in PeopleSoft Quality.
Third-Party Applications
Many companies implementing manufacturing systems use automated collection devices or systems to assist in quality inspection and control. Through the use of the PeopleSoft Integration Broker technology, you can pass quality information collected from these devices to PeopleSoft Quality.
The third-party system passes quality control information to PeopleSoft Quality using the Quality_Data_Submit service operation.
See Understanding the Integration of PeopleSoft Quality With Third-Party Applications.
