Integrating With PeopleSoft Manufacturing
This topic provides an overview of Manufacturing integration with Quality.
Pages Used to Integrate With PeopleSoft Manufacturing
| Page Name | Definition Name | Usage |
QS_APP_DEF |
Control data-entry and analysis-field input requirements by maintaining application fields categorized as hierarchy or traceability. |
Record Completions and Scrap - Production Selection Page |
SF_COMP_SELECTION |
Select the production IDs or production schedules for which you want to record completion and scrap information. |
Record Completions and Scrap - Record Completions/Scrap Page |
SF_COMPL_ID |
Enter completions and scrap data for production IDs and production schedules. |
Understanding PeopleSoft Manufacturing Integration With PeopleSoft Quality
When you define a manufactured item, you will create a bill of material and routing for it. The bill of material can contain one output or multiple outputs. Using the routing, define manufacturing operations and if machine, labor, or both requirements are required at each operation on the routing.
Then determine how to manufacture the item. If you use a non-repetitive process, create production ID's for the items. If you use a repetitive process, create production schedules. In either case, determine at what operations to record completions for the item on the shop floor.
When recording operation completions and scrap information against a production ID or schedule for any production type (production, rework, or teardown) using Manufacturing, you can immediately initiate a data-entry session in Quality. When you click the Quality link on the Record Completions/Scrap page, the system starts a quality data-entry session, and it passes hierarchy and trace fields from the production ID or schedule to Quality.
After transferring to Quality, enter sample information for the manufactured item being completed. The quality control plan defines the sampling requirements. After entering data, return to Manufacturing to continue to work on the production ID or schedule.
PeopleSoft provides the following predefined quality functions for integration between Manufacturing and Quality:
COMPLETIONS
COMPL NO MC (completions no machine code)
COMPL NO OP (completions with no operation sequence)
Reference the appropriate quality function when you define the control plans for the record completions and scrap process for a manufactured item.
COMPLETIONS
If you define manufactured items with routings, where the operations where you record completions are associated with a work center containing machines, then associate the completions process quality control plans with the COMPLETIONS predefined quality function. In this case, when recording completions against a production ID or schedule for the manufactured items, enter an operation sequence. That operation is associated with a work center containing one or more machines.
COMPL NO MC
If you define manufactured items with routings, where the operations where you record completions are associated with a work center that does not contain machines, then associate the completions process quality control plans with the COMPL NO MC quality function. In this case, when recording completions against a production ID or schedule for the manufactured items, enter an operation sequence. That operation is associated with a work center that does not contain a machine.
COMPL NO OP
If you do not create routings for manufactured items, associate the completions process quality control plans with the COMPL NO OP quality function. In this case, when you record completions against the production ID or schedule for the manufactured items, you do not enter an operation sequence, because you do not have a routing.
Also, if you define manufactured items that have routings, but you do not record an operation sequence, when recording completions against a production ID or schedule for the manufactured items, associate the completions process quality control plans with the COMPL NO OP quality function.
Quality Functions Page
Use the Quality Functions page (QS_APP_DEF) to control data-entry and analysis-field input requirements by maintaining application fields categorized as hierarchy or traceability.
Navigation:
Select one of the three predefined quality functions for Manufacturing. This table lists the fields that are available for use with the specified function:
COMPLETIONS Quality Function
| Stream Hierarchy Fields | Trace Fields |
COMPL_OP_SEQ |
BOM_CODE |
INV_ITEM_ID |
DT_TIMESTAMP |
MACHINE_CODE |
INV_LOT_ID |
PRDN_AREA_CODE |
OPRID |
PRODUCTION_TYPE |
PRODUCTION_ID |
WORK_CENTER_CODE |
RTG_CODE |
COMPL NO MC Quality Function
COMPL_OP_SEQ |
BOM_CODE |
INV_ITEM_ID |
DT_TIMESTAMP |
PRDN_AREA_CODE |
INV_LOT_ID |
PRODUCTION_TYPE |
OPRID |
WORK_CENTER_CODE |
PRODUCTION_ID |
RTG_CODE |
COMPL NO OP Quality Function
INV_ITEM_ID |
BOM_CODE |
PRDN_AREA_CODE |
DT_TIMESTAMP |
PRODUCTION_TYPE |
INV_LOT_ID |
OPRID |
PRODUCTION_ID |
RTG_CODE |
Related Topics
Defining Production Management Information for PeopleSoft Quality
Before Manufacturing can integrate with Quality through the record completions and scrap process, define the following information in Quality.
PeopleSoft Quality Business Unit
The following list describes the business unit:
You can define a Quality business unit that matches the Manufacturing business unit where you are recording completions and scrap information for the processes.
You can define configuration information in Quality by using the SetID associated with this Manufacturing business unit for the quality control tables.
Traceability sets and attribute groups in Quality are associated with a SetID.
Measurement plans and control plans are associated with a Quality business unit. In the case of integrating with Manufacturing, the Manufacturing business unit and the Quality business unit have the same name.
Traceability Set
The three Manufacturing quality functions define the hierarchy fields and trace fields that you use in the data-collection process.
When defining the traceability set for Manufacturing, reference one of the predefined quality functions: COMPLETIONS, COMPL NO MC, or COMPL NO OP.
Attribute Groups
Define attribute groups to produce concise and relevant selection lists for quality users. Define categories once, then future references to them appear in the selection criteria list.
Measurement Plan
When defining the measurement plan, use one of the predefined quality functions: COMPLETIONS, COMPL NO MC, or COMPL NO OP. These plans include variables and attribute characteristics to capture real manufacturing quality results.
Control Plan
The control plan brings together application, measurement, and control and response criteria for a specific product and process. In the case of the manufacturing completions process, depending on the quality function that you use, define control plans for items that have different completions criteria, when the shop floor manufactures the item.
When defining control plans for the completions process, consider these questions:
How do you record completions for the items you manufacture, if items have routings, do you specify an operation when recording completions against a production ID or schedule for those items?
If you specify an operation while recording completions, is that operation related to a work center that contains one or more machines, or does it not contain any machines?
Do you manufacture the item using a repetitive or non-repetitive process?
If the hierarchy fields in the control plan do not match the hierarchy fields associated with the production ID or schedule that you are completing, you receive a message when attempting to transfer from the Record Completions/Scrap page in Manufacturing to Quality. The message states: "Quality was not set up for this. Please review the Quality Control Plans." Some planning must be put into all the production combinations of item IDs, work centers, machine codes, and production areas when creating control plans for the environment.
In addition, when you create control plans, specify how you want to enter data against the control plan in Quality by specifying the data-entry method (by subgroup or by sample). The system uses the data-entry method to determine which pages appear for data entry in Quality.
When defining the control plan, use one of the predefined quality functions (COMPLETIONS, COMPL NO MC, or COMPL NO OP), the appropriate traceability set, and the appropriate measurement plan.
Passing Production Management Information to PeopleSoft Quality
You can pass information to Quality and record quality control information against a quality data-entry session, using either a production ID or production schedule for a manufactured item in Manufacturing.
Passing Information to PeopleSoft Quality Using a Production ID
To pass production information to Quality using a production ID with a single output or multiple outputs:
Create a production ID.
You can create production IDs for items that produce single or multiple outputs. Regardless of whether or not an item has a single or multiple outputs, it can have one of the following criteria:
No routing and no requirement for an operation sequence to be entered when recording completions while being manufactured.
A routing and no requirement for an operation sequence to be entered when recording completions while being manufactured.
A routing and a requirement for an operation sequence to be entered when recording completions.
The operation that you enter when recording completions is associated with a work center that does not contain any machines.
The operation that you enter when recording completions is associated with a work center that does contain one or more machines.
Retrieve and display the different production ID's using the Record Completions and Scrap - Production Selection page.
Display one of the previously created production IDs from step 2.
Enter completions and scrap data for one of the different structured production IDs, using the Record Completions/Scrap page.
Click the Quality link on the Record Completions/Scrap page to initiate a data-entry session and to access either the Data Entry - Subgroup Method page or the Data Entry - Sample Method page in Quality, depending on the data-entry method that you specified when you created the quality control plan.
If you have a production ID related to a manufacturing item that produces a single output, the Quality link appears next to the Previous Operations group box.
If you have a production ID related to a manufacturing item that produces multiple outputs, the Quality link appears in the Output Details scroll area of the page. In this case, you are able to record quality control information and create a quality data-entry session for any of the different outputs that are produced from the production ID.
View results and perform analysis on the data that you enter for the quality data-entry session.
To view results, enter corrective actions or log probable causes, or view the data in graphical format, use the Subgroup Method or Sample Method component in Quality.
Click the OK button on one of the pages in the Subgroup Method or Sample Method component to transfer back to the Completions/Scrap page in Manufacturing.
Passing Information to PeopleSoft Quality Using Production Schedules
To pass production information to Quality using a production schedule with a single output or multiple outputs:
Create a production schedule.
See the previous setup steps for item criteria.
Retrieve and display the different production schedules, using the Record Completions and Scrap - Production Selection page.
Display one of the previously created production schedules from step 2.
Enter completions and scrap data for the different structured production schedules, using the Record Completions/Scrap page.
Click the Quality link on the Completions and Scrap page to initiate a data-entry session and to access either the Data Entry - Subgroup Method page or the Data Entry - Sample Method page in Quality, depending on the data-entry method that you specified when you created the quality control plan.
Enter the quality control information against the quality data-entry session.
If you have a production schedule related to a manufacturing item that produces a single output, the Quality link appears next to the Previous Operation group box.
If you have a production schedule related to a manufacturing item that produces multiple outputs, the Quality link appears in the Output Details scroll area of the page. In this case, you can record quality control information and create a quality data-entry session for any of the different outputs that are produced from the production ID.
View results and perform analysis on the data that you entered for the session.
To view results, enter corrective actions or log probable causes, or view the data in graphical format use the Subgroup Method or Sample Method component in Quality.
