Entering, Maintaining, and Editing Quality Data
This topic provides an overview of how to create a new sampling and discusses how to enter, maintain, and edit Quality data.
Pages Used to Enter, Maintain, and Edit Quality Data
Data Entry From Access List Page
QS_DE_ACLEXEC
  • Select a control plan (by name) from a list.
  • Recall pending sessions from an access list. The mode is only available for pending sessions, not for completed sessions
Data Entry By Control Plan Page
QS_STRMROOT_SEL
  • Specify a control plan by entering its hierarchy fields.
  • Recall pending sessions using hierarchy fields.
Update Data By Control Plan Page
QS_STRMROOT_SEL
Recall completed sessions using hierarchy fields.
Recalling Sessions Using Hierarchy Fields
Select Pending Session Page
QS_SESSN_SEL
Select the pending session that you want to complete.
Select Active Session Page
QS_SESSN_SEL
Select the completed session that you want to edit.
Understanding the Creation of a New Sampling
To create a new sampling:
  1. Select the control plan that you are working on from either the access list or by entering hierarchy fields associated with the control plan.
    You can enter the readings for an inspection sampling for each characteristic through the Data Entry From Access List or Data Entry By Control Plan pages.
  2. Enter inspection readings for the various characteristics associated with a control plan.
    If you do not complete the plan, you can save the session and recall it at a later time for updates.
  3. Submit the data for analysis to assess control and view the current working chart for each characteristic.
  4. Enter probable causes for alarms or log corrective actions for any characteristic.
  5. Review the control plan and current sample results.
  6. View instructions on how to perform the inspection readings for all characteristics.
Use the Data Entry From Access List page (QS_DE_ACLEXEC) to .
Navigation:
Quality, and then Enter Sampling Information, and then From Access List, and then Data Entry From Access List
Select a control plan from an access list. This page simplifies the selection of repetitive control plans by inspection personnel.
For security, the Access ID field does not provide a prompt list.
Field or Control Description
Launch Default Data Entry
Click this link to launch the control plan that you specified as the default for this access ID.
Use the Data Entry By Control Plan page (QS_STRMROOT_SEL) to .
Navigation:
Quality, and then Enter Sampling Information, and then By Control Plan, and then Data Entry By Control Plan
Enter the hierarchy fields associated with the plan. The fields that appear vary depending on the quality function. In the lower portion of the page, the hierarchy fields associated with the specific quality function appear.
Recalling Pending Sessions From Access Lists
To recall a pending session from an access list:
  1. Access the Data Entry From Access List page.
    You can recall pending or incomplete sessions by using either the Data Entry From Access List or Data Entry By Control Plan pages.
    You can recall completed sessions for editing only by using the Update By Control Plan page.
  2. Click the Pending Sessions button next to a control plan to access the Select Pending Session page.
  3. Select the pending session to complete.
To maintain or complete a pending session:
  1. Access the Data Entry By Control Plan page.
  2. Enter the appropriate hierarchy fields for the target control plan.
  3. Click the Pending Sessions button to access the Select Pending Session page.
  4. Select the specific session that you want to complete from the list.
To edit a completed session:
  1. Access the Update Data By Control Plan page.
  3. Click the Pending Sessions button to access the Select Active Session page.
  4. Select the specific session that you want to edit from the list.
Use the Select Pending Session page (QS_SESSN_SEL) to select the pending session that you want to complete.
Navigation:
Click the Pending Sessions button on the Data Entry From Access List page or the Data Entry By Control Plan page.
Depending on the mode of entry to these pages, the system displays either a list of pending sessions to be completed or a list of completed sessions available to edit. Sessions are listed in descending order of creation date. In addition, the hierarchy fields associated with the quality function and control plan appear.
Session
Displays the pending or completed sessions.
Status
Displays the state of the session. Values include:
Saved: Pending sessions that you can maintain.
Analyzed: Completed sessions that you can edit.
The listed sessions are limited by the data persistence settings, the session data life days, and the edit data limit days that you defined for the quality function. This table lists the criteria that affects sessions:
Sessions Session Status Data Criteria
Pending
Saved
Current Date - Session Data Life Days
Completed
Analyzed
Current Date - Edit Data Limit Days
For example, suppose that you want to edit data for a completed session. The date is March 30, 2003, and the edit data limit days for the quality function is set to 20 days. The list of sessions that appear on this page are those sessions that you created between March 10, 2003 and March 30, 2003, with a session status of Analyzed.
