Using Attribute Statistics
Attribute statistics only apply to discrete data types, that is, count data. This type of data is typically associated with defect tallies.
The following table describes equations used with attribute statistics:
| Equation | Statistic | Alternate Equation Forms |
The sum of defects is the total count of all the defects in a sample. |
None |
This equation represents the average number of defects per unit. |
This equation represents the number of defects per 100 units. |
None |
This equation represents the number of defects per 1000 units. |
None |
This equation represents the number of defects per million units. |
None |
