Using Pearson Best-Fit Criteria
Quality uses Pearson criteria to determine the best-fit distribution for the sample. A K value, computed using the following equation, classifies the distribution as one of the following types:
gv_7bc7_sqsy7ea7
Pearson Frequency Curves
The following table describes Pearson frequency curves.
Type Description Criteria
1
Beta
gv_7bc6_sqsy7ea5
2
Uniform
gv_7bc5_sqsy7ea3
3
Gamma
gv_7bc4_sqsy7ea1
4
Non Central t
gv_7bc3_sqsy7e9f
5
Inverse Gamma
gv_7bc2_sqsy7e9d
6
Inverse Beta
gv_7bc1_sqsy7e9b
7
Student t
gv_7bc0_sqsy7e99
8
Normal
gv_7bbf_sqsy7e97
10
Exponential
gv_7bbe_sqsy7e95
