Using Variable Data-Control Charts
This table shows the use of variable data-control charts:
Equation Statistic
gv_7bac_sqsy7e71 gv_7bab_sqsy7e6f gv_7baa_sqsy7e6d gv_7ba9_sqsy7e6b gv_7ba8_sqsy7e69 gv_7ba7_sqsy7e67
where:
gv_7ba6_sqsy7e65 gv_7ba5_sqsy7e63
The
gv_7b95_sqsy7e61
/R chart, or average and range chart, is the most commonly used chart in SPC. Each point (k) on the
gv_7b95_sqsy7e5f
chart consists of an average
gv_7b95_sqsy7e5d
of individual
gv_7b86_sqsy7e5b
measurements within a subgroup of a constant sample size (n). The R chart represents the range (R), which is the maximum, individual measurement in the subgroup, minus the minimum.
gv_7ba0_sqsy7e59 gv_7b9f_sqsy7e57 gv_7b9e_sqsy7e55 gv_7b9d_sqsy7e53 gv_7b9c_sqsy7e51 gv_7b9b_sqsy7e4f
where:
gv_7b9a_sqsy7e4d gv_7b99_sqsy7e4b
The
gv_7b95_sqsy7e49
/s chart, or the average and standard deviation chart, is a variation of the
gv_7b97_sqsy7e47
chart typically used with subgroup sizes of greater than seven. Each point
gv_7b96_sqsy7e45
on the
gv_7b95_sqsy7e43
gv_7b94_sqsy7e41
of individual
gv_7b93_sqsy7e3f
gv_7b92_sqsy7e3d
The s chart represents the standard deviation
gv_7b91_sqsy7e3b
.within the subgroup of individual measurement.
gv_7b90_sqsy7e39 gv_7b8f_sqsy7e37 gv_7b8e_sqsy7e35 gv_7b8d_sqsy7e33 gv_7b8c_sqsy7e31 gv_7b8b_sqsy7e2f
where:
gv_7b8a_sqsy7e2d gv_7b89_sqsy7e2b
The X/MR chart, or individual and moving range chart, is typically used when measurements can't easily be formed into subgroups. Measurements may be expensive or destructive, or time periods between samples may be excessive. Each point
gv_7b91_sqsy7e3b
on the
gv_7b87_sqsy7e27
chart consists of an individual
Individual measurement
measurement. The MR chart represents the difference between the previous point and the current point (absolute value).
