Reviewing Receivables Activity for a Business Unit
You can use inquiry pages to look up customer balances and various summaries of other receivables activity at the business unit level.
Pages Used to Review Receivables Activity for a Business Unit
Out of Balance Customer Page
CUSTOMER_OOB
Determine whether a customer's balance matches the total amount of the customer's open items. This page is available only if the balance and the open item total do not match for a customer in the business unit.
Unit Activity Page
SYSTEM_ACTIVITY
View activity that you posted to a business unit. The system includes only payments that are completely posted in the totals.
Unit Cash Page
BUS_UNIT_CASH
View cash applied and cash received by a business unit.
Unit Draft Page
BUS_UNIT_DRAFT
View draft summary information at the business unit level.
Unit Aging Page
BUS_UNIT_AGING
View aging summary information at the business unit level.
Unit Aging Chart Page
BUS_UNIT_AGINGCHRT
View a chart with aging information for a business unit. The types of charts are two-dimensional bar, horizontal bar, line chart, or stacked bar.
Business Unit History Page
BUS_UNIT_HISTORY
View history summary at the business unit level.
Business Unit History Chart Page
BUS_UNIT_HIST_CHRT
View a chart with history information for a business unit. The types of charts are two-dimensional bar, horizontal bar, line chart, or stacked bar.
Receivables Activity Page
RUN_AR20005
Enter run parameters for the Receivables Activity report (AR20005). Use this SQR report to view activities and amounts for items with the ChartField values in the receivables (AR) distribution line specified on the run control.
The AR20005 Receivable Activity report assumes that any manually created overdue charge items are designated by a user defined entry type that is equal to or prefixed with OC. System-generated overdue charges already satisfy this criteria and are included in the Overdue Charge Amount column.
See also PeopleSoft Receivables Reports: A to Z.
Use the Out of Balance Customer page (CUSTOMER_OOB) to determine whether a customer's balance matches the total amount of the customer's open items.
This situation should never occur but if it does, then your database is out of sync. Contact the system administrator for your organization. This page helps the system administrator investigate the problem.
Navigation:
Accounts Receivable, and then Receivables Update, and then Out of Balance Customers, and then Out of Balance Customer
Unit Activity Page
Use the Unit Activity page (SYSTEM_ACTIVITY) to view activity that you posted to a business unit.
Navigation:
Accounts Receivable, and then Receivables Analysis, and then Review Receivables Information, and then Unit Activities, and then Unit Activity
Field or Control Description
Activity Type
Use to select a business unit activity. Each activity is divided into different categories of related system functions that perform the calculations. You can modify these categories on the System Functions 1 page.
Display Amount Switch
Choose to display either the base amount and currency or the entry amount and currency on this page.
This table lists the business unit activities, categories, and system functions that should be associated with the categories on the System Function 1 page:
Description Categories System Functions
Activity Type
Billing
Cash Applied
Discounts
Draft Management
Direct Debit Management
Overdue Charges
Maintenance
Refunds
Transfers
Write-offs - Maintenance
Write-offs - Payments
IT-01, IT-02
WS-01, -04, -05, -06, -07, -08
WS-02, WS-03
DM-01, -02, -03, -04, -05,-06
DD-01,-02,-03,-04,-05
FC-01
MT-01, -04, -05
MT-08, MT-09
TR-01, TR-02
MT-02, -03, -06, -07
WS-09, -10, -11
Activity Type/Origin/Bank Code
Billing
Cash Applied
Discounts
Draft Management
Overdue Charges
Maintenance
Refunds-Maintenance
Transfers
If you selected Breakdown by Origin in the Activity Type/Origin/Bank Code field on the System Function 1 page for a system function, the system displays one row per origin ID or bank code, depending on the system function. Draft and payment groups use bank codes; all other groups use origins.
IT-01, IT-02
WS-02, WS-03
DM-01, -02, -03, -04, -05, -06
FC-01
MT-01, -04, -05
MT-08, MT-09
TR-01, TR-02
WS-09, -10, -11
Entry Type
The system displays one row for each entry type that has activity.
Not applicable
Group-Type/Origin/Bank Code
The system displays one row for each group type. If you selected Breakdown by Origin in the Activity Type/Origin/Bank Code field on the System Function 1 page for a system function, the system displays one row per origin ID or bank code, depending on the system function. Draft and payment groups use bank codes; all other groups use origins.
Not applicable
Entry Type/Entry Reason
The system displays one row for each entry type and reason combination that has activity.
Not applicable
Unit Cash Page
Use the Unit Cash page (BUS_UNIT_CASH) to view cash applied and cash received by a business unit.
Navigation:
Accounts Receivable, and then Receivables Analysis, and then Review Receivables Information, and then Unit Cash, and then Unit Cash
Unit Draft Page
Use the Unit Draft page (BUS_UNIT_DRAFT) to view draft summary information at the business unit level.
Navigation:
Accounts Receivable, and then Receivables Analysis, and then Review Receivables Information, and then Unit Drafts, and then Unit Draft
Unit Aging Page
Use the Unit Aging page (BUS_UNIT_AGING) to view aging summary information at the business unit level.
Navigation:
Accounts Receivable, and then Receivables Analysis, and then Review Receivables Information, and then Unit Aging, and then Unit Aging
Use the Unit Aging Chart page (BUS_UNIT_AGINGCHRT) to view a chart with aging information for a business unit. The types of charts are two-dimensional bar, horizontal bar, line chart, or stacked bar.
Navigation:
Accounts Receivable, and then Receivables Analysis, and then Review Receivables Information, and then Unit Aging, and then Unit Aging Chart
Use the Business Unit History page (BUS_UNIT_HISTORY) to view history summary at the business unit level.
Navigation:
Accounts Receivable, and then Receivables Analysis, and then Review Receivables Information, and then Unit History, and then Business Unit History
Use the Business Unit History Chart page (BUS_UNIT_HIST_CHRT) to view a chart with history information for a business unit.
Navigation:
Accounts Receivable, and then Receivables Analysis, and then Review Receivables Information, and then Unit History, and then Business Unit History Chart
This example illustrates the fields and controls on the Business Unit History Chart page.
Enter search criteria, the chart selection, and the chart type, and then click Draw Chart to display the chart.
Use the Receivables Activity page (RUN_AR20005) to enter run parameters for the Receivables Activity report (AR20005).
Navigation:
Accounts Receivable, and then Receivables Update, and then Posting Results-Upd Pend Items, and then Receivables Activity Report, and then Receivables Activity
Remaining Amount
Enter an operator, such as equal to or greater than, and enter an amount. The report includes only items whose balance meets the condition.
Only Write-off Activity
Select to include only items that have a write-off activity.
ChartFields
Enter the ChartField values for each ChartField in the AR distribution line used to select items for inclusion in the report.
