Setting Up Follow-Up Letter Processing
Page Used to Set Up Follow-Up Letter Codes
| Page Name | Definition Name | Usage |
Letter Code Page |
LETTER_CD_TBL |
Define letter codes for follow-up letters. See Setting Up Follow-Up Letter Codes and the Letter Code Page. |
Understanding Setting Up Follow-Up Letter Processing
To set up follow-up letters, use the use the Letter Code (LETTER_CD) component.
PeopleSoft Receivables ships letter codes for follow-up letters. The system requires that you use the letter code of F for follow-up letters.
PeopleSoft also delivers a sample follow-up letter that you can modify to fit your needs.
Use this component to:
Set up follow-up letter codes.
Modify the sample follow-up letter.
Use the Letter Code page (LETTER_CD_TBL) to define letter codes for follow-up letters.
Navigation:
| Field or Control | Description |
Letter Code Type |
Select Follow Up Letter. |
Modifying the Sample Follow-Up Letter
PeopleSoft Receivables delivers a sample follow-up letter that you can modify to create a follow-up letter that is more suitable to your organization's needs. You can use BI Publisher to modify the ARX33004 report.
If you save the report file with a different name, you must create a process using the Process Definition page in PeopleSoft Process Scheduler that follows the model of the existing ARX33004 report. You also must create a new process definition that includes the two processes used to generate follow-up letters on the Job Definition page.
Editing BI Publisher reports is covered in detail in PeopleTools: BI Publisher for PeopleSoft.
See PeopleTools: BI Publisher for PeopleSoft, "Creating Report Templates" and "Defining Report Definitions."
