PeopleSoft Resource Management Implementation
PeopleSoft Setup Manager enables you to review a list of setup tasks for your organization for the products that you are implementing. The setup tasks include the components that you must set up, listed in the order in which you must enter data into the component tables, and links to the corresponding documentation.
PeopleSoft Resource Management also provides component interfaces to help you load data from an existing system into Resource Management tables. Use the Excel to Component Interface utility with the component interfaces to populate the tables.
This table lists the components that have setup component interfaces for loading data.
Component Component Interface References
RS_CM_COMPTNCY_TBL
RS_CM_COMPTNCY_TBL
See Establishing Application Setup Tables for Competencies.
RS_CM_PERSONAL
RS_CM_PERSONAL
See Creating Employee Data.
RS_CUST_INFO
RS_CUST_INFO
See Working with Customer and Contact Profiles.
RS_WRKR_CREATE
RS_WRKR_CREATE
See Establishing and Maintaining Employees and Non-Employees as Resources.
Other Sources of Information
In the planning phase of your implementation, take advantage of all PeopleSoft sources of information, including the installation guides, data models, and appendix guidelines.
See the product documentation for PeopleTools: Component Interfaces
