Recommendation Notification
This section discusses Recommendation Notification workflow.
Description
Information Type Description
Event Description
The following event triggers Recommendation Notification workflow:
Recommend a resource for a resource request on the Service Order - Recommend Resources page and save the service order.
Select an action of Recommend for a resource-and-resource request combination on the Staffing Workbench - Manage Utilization page and save the workbench.
Action Description
The system sends a worklist item to the resource as a notification that the resource is recommended for a resource request.
Notification Method
Worklist
This workflow is automatically activated.
Workflow Objects
Business Process
My Assignments (RS_RESOURCE_DSHBRD)
Activity
Recommendation Notification (RS_MYRECS_CHANGE)
