Work Definition Tables
Work definition tables store the rules for basic company-wide functions. PeopleSoft Resource Management uses the definitions for:
The frequency of pay cycles that defines standard hours for each resource.
Job codes designating each type of job that employees hold.
Holiday schedules.
Frequencies
You define frequency IDs along with a frequency type (such as monthly, weekly, bimonthly, daily, and hourly), and frequency annualization factor (the number of frequency periods that occur in a year). PeopleSoft Resource Management uses the Frequency Annualization Factor field value when calculating Availability factor fit scores.
