Checking Position Limits
You can check position limits for specified trees and tree nodes on an ad hoc basis.
Page Used to Check Position Limits
| Page Name | Definition Name | Usage |
POS_ADHOC_LIMITS |
Verify limits on an ad hoc basis. |
Ad-hoc Limit Check Page
Use the Ad-hoc Limit Check page (POS_ADHOC_LIMITS) to verify limits on an ad hoc basis.
Navigation:
Click the Check Limit button on the Check Position Limits page.
| Field or Control | Description |
Check Limit |
Select the SetID, tree name, and (optionally) the tree node for which you want to process a limit check. Then click the Check Limit button. If you do not select a tree node, the entire tree is selected. |
Tree Name |
Displays the tree name specified in the Tree Name edit box. |
Tree Node |
Displays the tree node, if specified in the Tree Node edit box. |
Utilization |
Displays the amount of the position limit used. |
Limit Min (limit minimum) |
Displays the minimum amount for this position limit. |
Limit Max (limit maximum) |
Displays the maximum amount for this position limit. |
Internal/External |
Displays the internal or external genesis of the position limit. Management or the board of directors typically define internal limits and the counterparty designates external limits. |
