Managing Activities When Project Costing is Not Installed
This topic discusses how to manage activities when Project Costing is not Installed.
You can also associate activities by service type.
Pages Used to Manage Activities When Project Costing is Not Installed
Service Activities page
SPB_SETID_ACTIVITY
Add or Modify service activities. Service activities are used to indicate how time is spent
Activities by Service Type Page
SP_ACT_BY_SVTYP
Select a service type and associate activities to it. The activities will be available for selection on Work Orders for the related service type.
Activities by Service Page
SPB_SRC_ACT
Select a service and associate activities to it.The activities will be available for selection on Work Orders for the related service.
Work Order Activities Page
SPF_WO_ACTIVITY (resource based), SPF_PRLOG_MS_PG (deliverable-fixed)
SPF_WO_RATE_ACT (deliverable-rate based), SPF_PRGLOG_MS_PG (deliverable-fixed price and milestone)
Select activities to associate with the work order.
If you have the SP_ADD_WO_ADHOC_ACT role action, then the Add Ad Hoc Activities button is displayed on this page.
When adding ad hoc activities to the Work Order Activities page, the system automatically adds the new activity to setup tables. After the activity is added to setup tables, the activity is considered as predefined and can be used for future work orders.
Creating and Managing Work Orders
Use the Service Activities page (SPB_SETID_ACTIVITY) to define service activities.
Navigation:
Services Procurement, and then Define Services Procurement, and then General Setup, and then Project/Activity Definitions, and then Service Activities
This example illustrates the fields and controls on the Service Activities page. You can find definitions for the fields and controls later on this page.
Field or Control Description
Description
Enter the activity description.
Activity Type
Select to indicate whether the activity is resource or deliverable-based.
Activity Sub Type
Depending on the value that you select in the Activity Type field, the system dynamically displays values.
If you select Resource as the activity type, the system returns values of Generic Activity and Specific Activity.
If you select Deliverable as the activity type, the system returns values of Milestone and Rate Based.
Status
Select the activity status. Values are Active or Inactive.
Billable
Select if the activity is billable.
Bid Factors by Activity
Click to access the Bid Factors by Activity page. You use the page to view or add bid factors to an activity.
