Setting Up Margin Indicators
This topic discusses how to set up margin indicators.
Page Used to Establish Margin Indicators
Billing Calculation Page
FO_JOB_BILLING
Enter margin indicators.
Use the Billing Calculation page (FO_JOB_BILLING) to enter margin indicators.
Navigation:
Set Up Financials/Supply Chain, and then Common Definitions, and then Resources Data, and then Jobcodes, and then Billing Calculation
Field or Control Description
Caution
Enter a margin percentage below which the system triggers a caution warning for an order. This indicates that the margin is below normal levels and changes the order to a Yellow status.
Critical
Enter a margin percentage below which the system triggers a critical warning for an order. This indicates that the margin is at an unacceptable level and changes the order to a Red status.
