Setting Up System Values for Amendments
Pages Used to Set Up System Values for Amendments
Document Format and Options Page
CS_CONFIG
Select an default value when amending documents.
Application Fundamentals: User Preferences - Supplier Contract Management Page
CS_CONFIG
Define user preferences for document authorizations. Document authorizations for processing two file formal amendments or a single file amendment are the same as for processing documents. They use the same settings and options.
Document Configurator Definition Page
CS_TMPL_TBL
Define amendment configurators.
Use the Document Configurator Definition page (CS_TMPL_TBL) to define amendment configurators.
Navigation:
Supplier Contracts, and then Manage Contract Library, and then Document Configurators
Use this page to indicate that a document configurator is intended for use with an amendment file. When you amend contracts with formal amendment files, the system requires an amendment configurator ID. Use the Use for Amendments only check box to associate a configurator to be used for creating amendment files. When you select this check box, the system makes this configurator available in the list of amendment configurators when creating amendments.
Also, make sure that you update the Availability Status field to Available after you complete the amendment contents.
When you create a formal amendment, you can use the amendment configurator to design the amendment contents. For example, you can create an amendment introduction section, develop clauses to include in the amendment, and include binds and rules as you would in the original document.
You cannot include contract wizards in amendment configurators. This option is disabled when you select the Use for Amendments only check box.
