Configuring Vertex O Series Integration
This section discusses how to activate the TAX_INTEGRATION service operation queue, activate the service operations, activate the routings, and activate the PSFT_TAX node.
Pages Used to Configure Vertex O Series Integration
| Page Name | Definition Name | Usage |
IB_QUEUEDEFN |
Activate the TAX_INTEGRATION service operation queue. |
IB_SERVICE |
Activate the service operations. |
IB_SERVICETRNGS |
Activate the routings. |
IB_NODE |
Activate tax node. |
Queue Definitions Page
Use the Queue Definitions page (IB_QUEUEDEFN) to activate the TAX_INTEGRATION service operation queue.
Navigation:
PeopleTools, Integration Broker, Integration Setup, Queues
For the TAX_INTEGRATION queue, verify that the Queue Status is Run.
Service Operation - General Page
Use the Service Operation - General page (IB_SERVICE) to activate the service operations.
Navigation:
PeopleSoft delivers service operations in PeopleSoft Integration Broker with a default status of Inactive. You must activate each service operation before attempting to send or receive data from a third-party source, such as Vertex. To setup a service operation use the information in the table below and refer to the setup instruction in Setting Up Service Operations
| Service Operation | Direction and Type | Handlers | Chunking Available? | Integrates With |
DO_TAXCALC_REQ |
Outbound Synchronous |
Not applicable |
No |
Vertex O Series or another third-party tax supplier |
GET_GEOCODES_REQ |
Not applicable |
No |
Vertex O Series |
See PeopleTools: Integration Broker Service Operations Monitor
Use the Service Operation - General page (IB_SERVICETRNGS) to activate the routings.
Navigation:
Click the Routings tab.
Activate the DO_TAXCALC_REQ_V2 and the GET_GEOCODE_REQ_TAX routings for the PSFT_TAX node.
For the DO_TAXCALC_REQ_V2 routing, set the PrimaryURL property to the endpoint of the Vertex tax calculation request function.
Typically this will be:
http://<host:port>/pgc/servlet/taxcalc. Replace <HOST:PORT> with the address of the Vertex PeopleSoft generic connector. -
For the GET_GEOCODE_REQ_TAX routing, set the PrimaryURL property to the endpoint of the Vertex tax area request function.
http://<host:port>/pgc/servlet/taxarealookup. Replace <HOST:PORT> with the address of the Vertex PeopleSoft generic connector.
See Manage Routing Definitions, PeopleTools: Integration Broker
