Defining Par Location Data for the SRS Application and the PeopleSoft System
This section describes the procedures and application functions used to maintain par location data in PeopleSoft Inventory and the SRS application.
To maintain par location data in PeopleSoft and the SRS application:
Create surgical resource par locations in PeopleSoft Inventory.
Define the operating room resource locations as par locations in PeopleSoft Inventory using the Par Location Definition component. All item and par location data is set up and maintained in the PeopleSoft system.
Run the Full Data Publish process to initially populate the SRS application with item data.
Use the Full Data Publish process to publish a full-data replication of the par locations for the initial implementation using the PAR_LOCATION_FULL_SYNC service operation (EIP) in PeopleSoft Integration Broker. This process should be run once the par locations are defined. You use this service operation to initially populate the SRS application with par location item data.
Save changes to the Par Location Definition component to update the SRS application.
All subsequent changes saved to the Par Location Definition component for existing par locations are sent to the SRS application in partial-data replication EIP (PAR_LOCATION_SYNC service operation) using the Par Location Definition EIP. These partial-data replications are published when saving the Par Location Definition component to keep the SRS application current with ongoing PeopleSoft Inventory par location definition and item changes.
Related Topics
