Implementing an SRS Application Integration
  • Define par location data for the SRS application and the PeopleSoft system.
  • Stock case carts from a surgical resource par location.
  • Maintain item replenishment data in the SRS application and the PeopleSoft system.
  • Restock a surgical resource par location.
