Example: Processing the Sales Order Acknowledgement EIP
This section discusses processing the Sales Order Acknowledgement EIP.
Pages Used to Process the Sales Order Acknowledgement EIPs
Publish Outbound Message Page
IN_RUN_PUB_MSG
Initiate the outbound message publish process for outbound SCM messages that use the batch publish design pattern.
Order Acknowledgement Message Selection Criteria Page
OM_RUN_OUTBOUND_EC
Enter processing options for the Sales Order Acknowledgement outbound messages. You can select processing options for only one message at a time.
Use the Publish Outbound Message page (IN_RUN_PUB_MSG) to initiate the outbound message publish process for outbound SCM messages that use the batch publish design pattern.
Navigation:
SCM Integrations, and then Publish Outbound Message
This example illustrates the fields and controls on the Publish Outbound Message page. You can find definitions for the fields and controls later on this page.
Click the Sales Order Acknowledgement check box, and click the Sales Order Acknowledgement link to access the Order Acknowledgement Message Selection Criteria page.
This example illustrates the fields and controls on the Order Acknowledgement Message Selection Criteria page. You can find definitions for the fields and controls later on this page.
