Par Location Count
You can download par location count information for use in a hand-held bar code device. You can select the following options to download:
One par location at a time.
All par locations for a par location group.
All par locations for a specified business unit.
All par locations.
Below is the layout of the par location download and upload file.
The download process creates a .dwn file of 404 characters per record from the par location definition tables (CART_ATTRIB_INV and CART_TEMPL_INV). The upload expects the same file layout, 404 characters per record as a .upl file. The upload process updates the par location count tables (CART_CT_INF_INV). Each par location is created with an unprocessed status, and you can view them on the Par Location Count Inquiry page.
| Contents | Format |
BUSINESS_UNIT |
5 |
INV_CART_ID |
15 |
CART_GROUP |
5 |
CART_REPLEN_OPT * |
2 |
SHADOW_FLAG * |
1 |
QTY_OPTION * |
2 |
INV_ITEM_ID |
18 |
DESCR |
30 |
COMPARTMENT |
10 |
COUNT_ORDER |
4 |
COUNT_REQUIRED * |
1 |
SUFFICIENT_STOCK * |
1 |
CART_REPLEN_CTRL * |
2 |
CART_COUNT_QTY * |
16 |
DEFAULT_QTY |
16 |
QTY_OPTIMAL |
16 |
FOQ (Fixed Order Qty) |
16 |
QTY_MAXIMUM |
16 |
UNIT_OF_MEASURE |
3 |
DISTRIB_TYPE |
10 |
DEPTID |
10 |
TRANSFER_COST |
15 |
PRICE_MARKUP_PCT |
15 |
CHARGE_CODE |
20 |
ACCOUNT |
10 |
ALTACCT |
10 |
OPERATING_UNIT |
8 |
PRODUCT |
6 |
PROJECT_ID |
15 |
CONS_NON_STOCK |
1 |
BCKORDR_CNCL_FLAG |
1 |
CHANGE_MARKUP_AMT |
16 |
CHANGE_MARKUP_PCNT |
15 |
MATERIAL_RECON_FLG |
1 |
USG_TRCKNG_METHOD |
2 |
LAST_OPRID |
8 |
LAST_DTTM_UPDATE |
26 |
Field-Specific Notes
See the field-specific information that follows.
CART_REPLEN_OPT
Specifies the way in which an item is to be replenished.
01 [Symbol_Wingdings_224] "stk" or "stock" (creates an MSR).
02 [Symbol_Wingdings_224] "less" or "stockless" (creates a staged purchase order).
03 [Symbol_Wingdings_224] "nons" or "non-stock" (creates a requisition).
04 [Symbol_Wingdings_224] "not replenished" (item is not to be replenished).
The system uses stockless and non-stock replenishment options only if PeopleSoft Purchasing is installed.
SHADOW_FLAG
The shadow par location flag, which has an online label of not replenished, appears on the hand-held bar code device. This informs the user that this par location is not to be replenished.
QTY_OPTION
A hand-held bar code device can modify this field.
The quantity options for each par location count appears by default based on the default quantity option that you defined on the Par Location Group Definition page.
If the default quantity option is count, the system prompts the user to enter the quantity on hand on the par location. If the default quantity is request, the system prompts the user to enter the requested quantity.
Values are:
01 [Symbol_Wingdings_224] "c" or "count qty."
02 [Symbol_Wingdings_224] "r" or "request qty."
COUNT_REQUIRED
The COUNT_REQUIRED flag is evaluated to determine whether a count must be entered for an item. This flag is defined per item on the Par Location Group Definition page.
SUFFICIENT_STOCK
The SUFFICIENT_STOCK flag is available for entry on the hand-held bar code device if the quantity option is count qty. PeopleSoft provides this field, so that the user does not need to enter a count for that item if it is not necessary.
CART_REPLEN_CTRL
Identifies how the order quantity is to be calculated if the quantity option is set to count quantity.
01 [Symbol_Wingdings_224] "Par"
02 [Symbol_Wingdings_224] "FOQ" or "Fixed Order Qty"
03 [Symbol_Wingdings_224] "Min/Max"
CART_COUNT_QTY
Related Topics
