Physical Accounting
You can use a hand-held bar code device to conduct your physical counting event. To ensure data transfer accuracy, first configure the download and upload file formats for the counting sheet according to the layout presented in the next table. All fields must be left-justified, with a space between each field.
Field Comments Format
INV_ITEM_ID
Required.
Char 18
STORAGE_AREA
Required.
Char 5
STOR_LEVEL_1
Required, if set up for the storage area.
Char 4
STOR_LEVEL_2
Char 4
STOR_LEVEL_3
Char 4
STOR_LEVEL_4
Char 4
UNIT_OF_MEASURE
Required. Must contain the stocking unit of measure (UOM) at the location.
Char 3
STAGED_DATE
Required. If the item is staged-date controlled, this field must contain the appropriate staged date. If the item is not staged-date controlled, include the filler default value that you established on the Installation Options - Inventory page in the Installation Options component.
MMDDYYYY
SERIAL_ID
Required. If the item is serial-controlled, this field must contain the appropriate serial ID. If the item is not serial-controlled, include the filler default value that you established on the Installation Options - Inventory page in the Installation Options component.
Char 20
INV_LOT_ID
Required. If the item is lot-controlled, this field must contain the appropriate lot ID. If the item is not lot-controlled, include the filler default value that you established on the Installation Options - Inventory page in the Installation Options component.
Char 15
CONTAINER_ID
Optional.
Char 10
QTY
Required. Must contain a quantity; zero is valid.
Nbr 16
UNIT_OF_MEASURE_COUNT
Required. Must contain a valid UOM for the item. If this UOM is different than the stocking UOM noted above, then the quantity is converted to the stocking UOM before updating the database.
Char 3
ITEM_DESCR
Optional. For informational purposes only.
Char 30
COUNT_DTTM
Must contain a date. If the field is blank then the system does not update the row.
MM/DD/YYYY HH:MI:SS
